Radiator upgrade for a 2.8 stroker
Paynts
Post Fri May 16, 2014 12:50 pm
Does anyone know a cheap decent radiator upgrade, I don't mind a bit of cutting and welding
Post Fri May 16, 2014 1:00 pm
According to the Zone Wiki: "The standard 325i radiator will be fine as long as it’s in perfect (i.e as new) condition."
jmc330i
Post Fri May 16, 2014 1:46 pm
An M20 aircon rad is slightly larger (taller) than the non aircon rad, and is a direct replacement for the standard rad. Buy an aircon front valance for the extra slot or just cut a slot above the oil cooler cut out in your valance to allow airflow to the bottom of the aircon rad.
As above, a standard, good condition rad should be fine, but an aircon rad is an option.
James
'91 325i Sport
'93 318i touring 16v
bmwmaster
Post Fri May 16, 2014 8:26 pm
You could also search for an e30 324td radiator. Its also larger and fits perfect. Never had temp problems with it.
