325 engine on 320 gearbox ?
skivvey
Post Fri May 17, 2013 1:14 pm
hey guys been offered a 325 m20 engine and been told will fit onto my gearbox with same clutch and flywheel is this true and could anyone tell me the pros/cons off this swap is it a good idea ? thanks
leeparkes
Post Fri May 17, 2013 8:00 pm
Gearbox will fit and yes its a good idea there pretty much the same engine but an extra 500cc and about 50hp.
gromgsxr
Post Fri May 17, 2013 8:43 pm
the 320i gear box ratios are pretty close to the 325i sport box so better acceleration
e30den
Post Sat May 18, 2013 3:57 pm
gromgsxr wrote:the 320i gear box ratios are pretty close to the 325i sport box so better acceleration
This ^^^
jimbom30cab
Tech 1 freak
Post Sat May 18, 2013 5:35 pm
YES, it bolts straight on. the ratios are in the wiki.
