I've got an M20b25 swapped 316. When your driving every now and then it jolts and cuts in and out and gets worse the faster you go. Also when you go flat out it feels like it has flat spots and it wont idle smoothly.
We've checked the ignition side and it has spark. It also had several air leaks on the throttle body which we have stopped but it still wont run correctly?
E30 cutting out under load
