Hi,
Please can anyone tell me if these injectors are good to use on my M20 2.7. I heard something about bore washing if you use the wrong ones.
Asking as I have a new set. Bosh 060 0280150415 562 ?
Also any heads up on a good place for M/S mapping, someone who has good experience of an M20 so as to save trial and error? South of england preferred.
Injectors and mapping question.
- Contact:
Those are 166cc/min (16lb/hr) injectors. They should be adequate up to about 180hp with a stock fuel pressure regulator.
- Contact:
Standard M20B25 injectors are 147cc/min (14lb/hr). If you are going for over 200hp then you need at least 200cc/min (19lb/hr) injectors. The bosch 0 280 155 700 are a common swap. My 2.8L stroker is running those injectors without any issues and I'm currently making 182whp (roughly 205-210hp at the crank)
