header tank option
shedrool83
jmc330i
Early M20s had the header tank up near the battery tray.
I've seen an M20 using a rad with the integral expansion tank, but I don't know what rad it was or how it was plumbed. From memory, it was an M50 converted car that had an M20 refitted while some engine work was done, so it could of been an E36 rad.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
shedrool83
HairyScreech
Been done a few times, not sure on the specifics but if you search for "tropical radiator" or e36 or 5 series rad then you should find some leads.
shedrool83
eko
- Old timer
I did an M20 swap recently on one of mine and used and E36 aircon rad.
Ill find a pic...
Ill find a pic...
shedrool83
Curr946
Jake youll need to change the pipe that runs along the side of the block as this has a t off it running to the expansion tank. IIRC I used one from a preface lift when I used an E36 rad a few years back on a 2.5 conversion.
I'm sure I should have one in the garage. Ill look it out plus some other bits.. I will fill your van yet
If your wife must learn to drive, don't stand in her way!
Gunni
Use this radiator.
http://www.ebay.co.uk/itm/BMW-E36-3-SER ... 416cd789d7
Carries most amount of coolant, has the header tank as well. Makes for the cleanest most efficient cooling system.
Kedge
It's the facelift pipe you need to do this.Curr946 wrote:Jake youll need to change the pipe that runs along the side of the block as this has a t off it running to the expansion tank. IIRC I used one from a preface lift when I used an E36 rad a few years back on a 2.5 conversion.
You've not said what whether your M20 is a pre or post facelift version. You need the plumbing and water pump from a facelift car.
eko
- Old timer
No trouble fitting it.
Just routed the original M20 pipe towards the bottom of the rad rather than upto the original header tank location.
Ok the pipe wasnt a perfect fit but it fitted fine with no kinks in it.
I just used the plastic hose bracket found on M40`s etc which clips on the chassis rail.
Had to shorten the bottom hose a couple of inches as it was too long.
shedrool83
shedrool83
jimmyspeed
if the belts old , you could try a new one to bring it a bit further away or maybe even a non standard one ?
shedrool83
jimmyspeed
no worries - if the toothed adjuster is in the way you could cut it down and re-weld it too
would just mean a bit less adjustment and more belt changes
am watching with interest as i need to fit new rad and do away with the header tank, so this has been a big help!
steve_k
shedrool how did you go about fitting the new rad?
got to get a new one myself & i'm going for the one in the link from willnz.
any help/advise would be great.
T.I.A.
T.I.A.
shedrool83
The rad in the link was a straight fit i.e it sat on the factory brackets at the bottom and the top bracket holds it fine.
My top and bottom rad hoses fitted straight on as did the hose that would go to your oem header on a facelift m20.
As above the only slight issue is the power streering ajusting bracket being abit to close to the old header hose.
Thats the rad i used.
steve_k
cheers dudeshedrool83 wrote:The rad in the link was a straight fit i.e it sat on the factory brackets at the bottom and the top bracket holds it fine.
shedrool83
steve_k
fantastic cheer's dudeshedrool83 wrote:Yes it does.
nickphine
I used my 318is rad on my m20 conversion as the cores were identical. Always worked perfectly, combination of 318is and 325 hoses as i recall, all standard. I had to modify either the power steering pump or alternator bracket to get the bottom hose to clear if memory serves. It looked neat and held temp perfectly even on hot track days. Normal viscous fan too. Got some pics somewhere...
