Hi,
What are the specs for the valves on a 2.7 conversion? Standard cam. I just found a note from the guy who built it saying .10mm intake & .15mm exhaust. Are these correct as I know standard is .25mm?
Valve clearances on a 2.7
maggspower
- Turbo Farmer Tractor Driver
No stick with .25mm cold.
reggid
unless you have an aftermarket cam that says otherwise use stock numbers maybe slightly looser will smoothen things out
E30 325is with M20B31
