I know that m50 2.5 rods can be used in an m20 but do the m20 pistons fit straight onto them?
Can an m50 crankshaft be used too? Would there be any advantage?
M50 rods
Pistons go straight on yes, only benefit is weigh reduction, no advantage to using M50 crank
HairyScreech
And if weight reduction is the game then M52B28 rods is what you want, same size and strength and about 100g lighter each.
driftwood
Yes, I'm looking for lighter rods for a 2.5 build. Haven't found any yet.
maggspower
- Turbo Farmer Tractor Driver
M52B28, very nice rods for an M20B25 build.
driftwood
Are m52b28tu rods the same? They are the same length.
HairyScreech
Identical to b25 ones but 100g lighter. (well obviously a different design but you know what i mean).
driftwood
Well I found a set of rods. They do look rather thin! They should be m52 2.8 items. Anyone got a link to some pictures of m20, m50, m52 rods? I just want to make sure I have the right ones.
maggspower
