finally got round to fitting my X-pipe & found out that i can no longer use the current mounting bracket (the one that bolt's on to the gearbox) so right now the exhaust is hanging lower than it should & that not good with the size of the speed humps round here as i don't fancy ripping it off
i've had a look on bmwfans.info & the only one i've found so far is part number's 4 & 5 for a e36 318is.
http://bmwfans.info/parts/catalog/E36/C ... ion_parts/
thing is will it fit?? i need a clamp thats about 60mm - 65mm diameter to go round the the middle of the X-pipe (right where the old bracket fit's round the old twin pipe system.
so would it fit?
the only reason the X-pipe is so close to the end of the down pipe's is because i don't fancy losing any bottem end/mid range grunt.
help me out if you can folk's as this is starting to do my head in.
