E21 M20 Engine swap into an E30
I have a good E21 engine (Distributor on side of engine)that I want to swap into my e30. What should I look out for. I have the complete harness etc.. Is the ECU different etc...
Andyboy
- Alpina Colada
Don't.
E21 engines are either fitted with a hopeless carburettor (320) or a prehistoric fuel injection system (323i). No ECU's either.
201964
Mine is a M20B20 with fuel injection, must look to see if it has an ECU connectionAndyboy wrote:Don't.
Andyboy
- Alpina Colada
The only 2.0 E21 with injection was a four cylinder with K Jet.201964 wrote:Mine is a M20B20 with fuel injection, must look to see if it has an ECU connectionAndyboy wrote:Don't.
201964
Must be from an E28 then as its 6 cyl fuel injected
1988 Convertible Auto 320i Black
HairyScreech
Pictures? i'm sure someone on here can identify it from a picture.
What would be the reason for putting it in?
201964
I have identified as an early version of the M20B20 engine. I took the engine from a 1988 E reg E30, which the engine obviously had been put in as everything was new (new radiator, new leads etc...)HairyScreech wrote:Pictures? i'm sure someone on here can identify it from a picture.
My engine is worn lacking on power, oil thins after a couple of hundred miles and smells of petrol
