Any feedback will be appreciated
EGT sensor mounting!
dot
Hi all! I'm finally getting my m20 turbo build under way I'm currently making my down pipe and I'm not sure where I should mount my EGT Sensor I have read the manifold is the ideal place,but my manifold is cast and I don't fancy drilling it. where have you mounted yours??
ross2009
manifold is the best place to have it really you want it on no 6 runner where it gets the hottest im not sure if putting it on the down pipe will have the same effect might be wrong
