M20B23 engine swap to M20B25
antonni95
Post Fri Apr 27, 2012 3:49 pm
I have a 5 speed 85 323i and a spare M20B25 from a 88 325iS - apart from simply removing the old and dropping in the new, what else is needed? I know it is going from L-jetronic to motronic so the ecu will be replaced but what else has to be changed? Wiring loom - full or just engine? etc
thanks
ross2009
Post Fri Apr 27, 2012 4:14 pm
just the engine loom need changing it goes thro a grommet near the battery tray its pretty easy swap
Turbo M20
v8 project 6.0 twin turbo
antonni95
Post Sat Apr 28, 2012 12:15 am
cool, thanks
Kedge
Post Sun Apr 29, 2012 9:30 pm
Not going to be that easy actually.
Since you're going from a M20B23 you'll have the old style small square C101 plug, whereas all 325i's have the later round C101 plug. This is where the engine loom connects to the cars main loom by the fuse box.
Best bet i think will be to source the C101 from a 325i car with a few inches of wiring and splice it in, or you change the whole car loom instead..........i know people have gone down the route of changing the whole car loom doing this swap.
Here's the wiring info for the two different plugs;
http://www.e30zone.net/e30zonewiki/index.php/C101
You'll want all the M20B25 ancillaries, loom and ECU as well since the '88 M20B25 will be running Motronic 1.3
Instagram - Kedge85
