e30 2.5 fuel line issue
kebabdan
hey im jus wondering when im cracking the engine... the petrol is coming out from the hose which connects to the fuel filter to the pipe leading up onto the inlet manifold? is that the correct way around or should the pipe which is pumping fuel be going directly to the injectors ?
DAN MORGAN
kebabdan
sorry the one that is feeding goes to the fuel pressure regulator... is that incorrect and i have them the wrong way around ?
DAN MORGAN
ross2009
no thats wrong the one that feeds goes to the fuel rail the return on the pressure regulator
