early m20 fitted to late car what wire do i join to make rev
s9jja
Post Mon Feb 06, 2012 6:04 pm
hi there all got my car up and running its a early hi comp engine and the car is a late one. does anyone know what wire i need to join from the ecu the white plug to where and what colour wires?????????
evilming318ia
Post Tue Sep 04, 2012 8:23 pm
There should be a 3 pin plug near the ecu you must connect one of them to a back cable in the rev count in order to make it work did this on mine and it worked must have a look in the car to figure out what color it is in the 3 pin connector
