320 head on a 325 block?
antony_e
Post Sun Nov 06, 2011 9:54 pm
As above ive had a search but nothing i can make a good yes or no to
appreciate any help
ant
HairyScreech
Post Sun Nov 06, 2011 10:51 pm
its generally a no, take a look at page 12 of my thread.
antony_e
Post Sun Nov 06, 2011 10:53 pm
Always worth a try i guess cheers for the reply
Quaser
Post Sun Nov 06, 2011 10:54 pm
no - 325i pistons are shaped - 320i are flat!
HairyScreech
Post Sun Nov 06, 2011 11:07 pm
which is what i was referring to there, you need to remove material from the head in order to prevent the pistons clashing at the squish band.
the head in my thread has been modified to suit.
although.... its just not worth it, all you will get is a slower car.
**BANNED**
Post Mon Nov 07, 2011 12:36 am
Depends on what pistons you use...
I am using a 325 block with a 731 head,but eta pistons,rods and crank.... winkeye
Youth is wasted on the young.
HairyScreech
Post Mon Nov 07, 2011 12:41 am
very true, in general a 731/320 head MUST have FLAT pistons and an 885/325 head MUST have BOWLED pistons.
otherwise you are buggering up the design of the combustion chamber.
have you seen the latest on the m20 thread? there may be help for you eta piston knuckle draggers yet. :P
**BANNED**
Post Mon Nov 07, 2011 1:37 pm
HairyScreech wrote: there may be help for you eta piston knuckle draggers yet. :P
I'm watching!
Now if we can combine M50 sequential fueling and COP,can we get an engine that 'looks' stock,but is more efficient?
HairyScreech
Post Mon Nov 07, 2011 6:15 pm
thats the plan.
cause with the way fuel prices are going.......
(ohh and lpg, as the m50 management will run lpg a LOT better than the m3.1)
