The cooling fan ?
imye30
Post Sun Oct 09, 2011 2:10 pm
Apart from the standard fan on the 325i is there option to up grade this to a different type
leeparkes
Post Sun Oct 09, 2011 2:12 pm
Electric?
Pointless, the standard viscous does the job perfectly.
You could fit an electric fan, but why cause yourself more work
Post Sun Oct 09, 2011 2:37 pm
Upgrade in what way? As said above, the standard set up does all that's required, so what is there to upgrade?
imye30
Post Sun Oct 09, 2011 3:40 pm
Some quoted if I don not use the oil cooler u need to change the fan set up
leeparkes
Post Sun Oct 09, 2011 3:44 pm
imye30 wrote:Some quoted if I don not use the oil cooler u need to change the fan set up
There full of shoit.
Post Sun Oct 09, 2011 10:36 pm
Total rubbish.
HairyScreech
Post Tue Nov 01, 2011 2:25 am
modern semi-synths can come just fine with the heat of the m20 without the heat exchanger.
DmcL
Post Tue Nov 01, 2011 8:14 pm
im running an electric fan setup on mine.. no earth shattering gains anywhere or anything but wngine seems to warm up marginally quicker and temperature seems to be kept around the halfway mark a bit better.
im running a 16 inch universal push/pull mounted on the front of the rad as a pusher controlled by one of those cheapy adjustable thermostats with the probe u slip into a coolant hose. running that setup for a good 4 months or so with no issues.
WMMotorsports
hongkongfuey
Mad-tango-geezer
Post Mon Nov 14, 2011 12:05 pm
im using a 14" electric volvo push fan, i find it better in traffic, doesnt sap the power of the car like a viscous does ,also in traffic fan will come on and cool engine better than viscous imo,
and before anyone pops up with comments, this is my opinion,
and my viscous, blue sensor, and any other part of my car was fine and running right
with cars like mine,
