It is possible at m20b20 block bore cca 83.7mm ? (original cca 80mm ) I can b25 pistons + 130mm connecting rods and m52 crankshaft in new modified block for b25 bore
thx , sorry for worse translation
Not strictly true. The core used in casting the B20 is different to that used in the B25, so the casting thickness for the cylinder is thicker in the B25.daimlerman wrote:Both the 2 litre block and the 2.5 litre block are identical,except for bore size.
