Injectors?
Jacko_
Sat Aug 27, 2011 12:04 am
Hiya guys, i bought a M20 basic build 2.7 (ETA block conplete and 325 head) Now i realise this will not give massive amounts of power but that's ok it's not what i want from this engine but does anyone know if i can use M52 injectors? Thing is i've not got any M20 2.5 injectors but i do have some M52 ones kicking about.
Now i've not touched this engine for some time and i've just started putting it back together again and i could do with a little help on the wiring side of things, the engine was installed in an E30 and is going into an E28 520 - could anyone help with links to wiring information - is it a simple case of unplugging the old loom from the fuse box and plugging the new in?
What should i look out for when installing this? I can't remember what plug goes where so any diagrams would be really helpful.
Here's a little picture for you....looking forward to installing it now :D
Thanks.
E21 323i with 2.8 M52 on TBs (fast road / track car)
E28 M535i (track car project)
E36 328i touring (drift wagon daily driver)
**BANNED**
Sat Aug 27, 2011 11:33 am
Have a read here;
http://www.e30zone.net/modules.php?name ... ic&t=83367
Seem to remember that E28/520i uses the earlier Motronic,as your photo's show a toothed wheel on the front pulley,I assume you will be using the later engine management?
The above warning will be relevant to your instalation!
Engine loom should be easy to sort out,the CPS will have a wire attached that needs carefull positioning across the front of the engine behind the fan pulley,to a socket just under the diagnostic socket,the lead that fits around one H/T lead plugs into the other one here.
There's a small,round,plug/socket(injector loom,temp sensors)(called C191)that mounts to the steel frame under the inlet manifold,and the oil pressure switch connector down the front on the exhaust side,close to the CPS.
Whole lot should run to a large round plug/socket(C101)located by the fusebox(on E30,cannot remember for E28!)
ECU plug should also be on this loom,it should feed through the bulkhead near the steery column.
You may have an issue with the rev counter,early E30 signal feed is slightly different,I have never had to sort one out myself so cannot remember the detail,'Danthe' is the guy to ask for help if you get stuck there.
Youth is wasted on the young.
Jacko_
Sat Aug 27, 2011 10:38 pm
Thanks for you help matey.
The story goes a little something like this...The engine (2.7hybrid) was installed into a 320 i think (88 or something this is all off the top of my head) with the later motronic ECU etc. This was how i bought it from a chap on here, he had stripped his baur as it was rotted and he hit some dogs while driving it and i bought the shell with the engine installed and stripped the rest of it and then put the engine on the stand stripped it fully down and then shrink wrapped it and forgot all about it till now (about 2 years i'd say!!)
Now the E28 i'm installing it into has motronic with a small connector to the ECU so i'm assuming this must be earlier type. Now the 2.y7 loom has the injection section you talk of and a big round diagnostic connector. It also has 4 relay positions but i've removed them all so no idea what relays i need to use here? It also has from a quick look the same type of connector that goes to the fuse box but i've not double checked this and i don't know if the wiring positions are suitable for me to just plug and play? Any help on this area would be great as its all a distant memory now.
Also, any help on water and vacuum pipes would be great. I'm hoping most of it is similar to that of the 2.0 engine i've just removed so will be looking at this later tomorrow in more detail.
Here's another little pic of the engine as she now stands...i'm really looking forward to getting this in a working it's been a long time coming ”“ old engine is now removed and engine bay cleaned up ready.
Thanks again
Regards
Jacko.
Jacko_
Sun Aug 28, 2011 12:08 am
I forgot...can i use M52 injectors at all? Any other injector i can get from the scrappers that will work? I really would like to get the full inlet built up and can't really without the injectors and loom done. :(
DmcL
Mon Aug 29, 2011 9:43 pm
M50 injectors can be used.. M50B25 injectors flow around 1.5lb/hr more than standard M20B25 ones and are also 4 pintle design.
out of all the different injectors i have run on my M20 those were the easiest to get ahold of and worked just as well as newer design pintles (the plastic bodied ones).
WMMotorsports
leeparkes
Mon Aug 29, 2011 9:47 pm
I always thought it was M50/b20 injectors used with an M20 as they are a similar flow rate.
Could be wrong though :)
DmcL
Mon Aug 29, 2011 10:15 pm
probably right.. i dont know the M50B20 injector flow off hand. ive run my B25 on tons of different high impedance injectors, biggest i have run so far was 30lb/hr which is like twice the standard size. i can tune the ECU for the injectors tho, if u just fired in 30lb injectors the car probably wouldnt even start from being drowned with fuel.
WMMotorsports
Jacko_
Thu Sep 01, 2011 11:05 pm
Thanks for the info guys...i was kinda thinking that a new design would have worked. I was running out of time so bought a set of M20 2.5 injectors but will get a set of M50 injectors when i'm next at the scrap yard and see how it runs.
I'm not after more power from these but better fuel economy would be nice.
DmcL
Tue Sep 06, 2011 6:59 pm
there are plenty more fish in the sea...
if u have a certain flow rate in mind there may be other cars u can pillage a set of injectors from other than another BMW.
FWIW ive got a set of mondeo v6 injectors (st24 i believe, 0280155771) and they are 17lb and high impedance so will drop right in without causing the engine to run insanely rich (maybe a little depending on the chip/tune tho). they are the newer bosch design injectors with the plastic body and 4 pintle tip.
also FYI when looking at bosch injectors part numbers on metal bodied injectors similar to the standard M20 injectors (be it single or 4 pintle) will always be 0280150***, the newer design plastic bodied injectors are usually either 0280155*** or 0280156*** so if u happen to be ringing around about injectors u can tell which type the injectors are by the part number on them.
and last but not least.. E36 323i/325i injectors are 0280150415 (light blue top) and E36 320i injectors are 0280150414 (grey top).
HTH :cool:
WMMotorsports
Wed Sep 07, 2011 10:14 pm
The M50 and M52 2.5 engines are green top, the M50 2 litre are a very light grey, I have some for sale here if any M20 modders are interested :wink: - http://www.e30zone.net/modules.php?name ... c&t=203711
DmcL
Thu Sep 08, 2011 1:27 pm
correct.. actually the same injectors on the 323i and 325i E36, also i believe the same for vanos and non vanos. 328i uses slightly larger injectors and M3 is larger again.
WMMotorsports
Thu Sep 08, 2011 1:56 pm
Jacko_ wrote: I'm not after more power from these but better fuel economy would be nice.
If it's economy you're after, the new injectors you require will be LPG ones.
Jacko_
Thu Sep 08, 2011 10:54 pm
haha very good Brian, i think i'll just stick with the standard injectors for now.
DmcL
Fri Sep 09, 2011 3:40 pm
FWIW 4 pintle injectors are marginally better for economy providing the tune is set correctly for the size of injectors u want to use. also a MAF conversion with a decent tune can help boost economy slightly as well.
im currently running an 80mm bosch MAF with 17lb mondeo ST24 4 pintle EV6 injectors and im running it a little on the lean side at low load cruising. im running AFR's between 14.5 and 15.5 in places which then drops down to the 13-14 AFR region as load increases and running around 13-13.5 AFR at full throttle.
economy is a little better as well as better response and more power, some of that is from the MAF and 4 pintle injectors but the bulk of the gains (power and economy) are from the tune i have come up with for this setup. i basically hald to re-do all of the fuel maps from scratch as the MAF works in a different way to the standard AFM and M30 AFM.
80mm MAF into modded airbox:
80mm MAF vs M30 AFM vs M20 AFM:
WMMotorsports
Quaser
Wed Nov 23, 2011 1:10 am
sorry guys - the m50/m52 injectors should not be used as they cause bore wash later on.
They are the wrong spray pattern and are designed for 24v heads, not 12v.
HairyScreech
Sun Nov 27, 2011 10:16 pm
again i have to ask what you base this on? (i say again as im sure this has come up before)
edit-
right it seems there is some kind of legend floating about that the m50 injectors cause bore wash when fitted to the m20.
firstly and i would like to make this clear from the start, what i write now is based on many years of theory and experience in other vehicle applications and i have no specific practice and empirical knowledge of these specific injectors, whats written here is to hopefully debunk myths and stimulate debate.
now firstly bore wash:
this is a phenomena created by an excess of unburned fuel in the cylinder to a level where it is capable of removing or diluting the oil film on the cylinder wall.
this problem is specifically caused by liquid fuel in the chamber.
there can be no other cause for this than liquid fuel remaining after or before combustion.
now in order for this to happen there has to be either :
1. seriously poor atomisation of the liquid fuel being introduced to the chamber by the fuel metering device (as that could always be a carb)
or 2. the much more likely and common scenario of a system calibrated to run far too rich (or not calibrated at all)
the ways to prevent this are three fold.
solve the over fueling
atomise the fuel better by in cylinder swirl/tumble
atomise the fuel better where it is introduced.
the m20 engine has a very good combustion chamber design and port arrangement that is capable of producing large scale swirl in the mixture and also has a decent squish band that will further mix things up, so its safe to say it can cope with a lot chucked at it in liquid from.
this is quite a fortuitous thing as the standard m20 in both carb and injected form sees a lot of poorly atomised fuel coming down the inlet port.
the standard injector and the carb set up will tend toward producing fuel in large droplets, with the design of the inlet manifold (which i will get on to later) the fuel will have a tendency to end up on the short side of the port floor, where it will be carried into the cylinder via the hurricane heading down the inlet port and past the valve,
now this situation of liquid fuel sitting on the port floor is bad for power and economy and emission, its just lucky that the heat of the port floor will vaporize a small amount, the air will pick up a bit more as it flows past and a large amount of the rest will be delt with by the swirl in the chamber.
unfortunately not all though, which is why the e30 injection system is a bit of a dinosaur in terms of economy and emissions.
all of this is ok provided the injectors are not pumping far too much fuel at the engine in the first place, when the engine is significantly rich across the whole range then there is just no way it can cope with atomising enough of the fuel to prevent some being left in the chamber, which is why you get soot, as this is fuel droplets that are too big undergoing pyrolysis.
very few engines can cope with being overfueled but most engines can cope with some amount of poor atomisation as this is the case in ALL engines to some extent, by design.
all engines with correctly sized injectors will at some point be forced to inject fuel directly into a port with a closed valve, this is due to the simple fact there is not enough time to get the fuel past the valve at high rpm.
which means all engines have to be able to cope with poor atomisation at high speed, its the low speed that causes trouble.
the m20 has this worse than most in stock from as firstly the fuel injector has a simple beam or pencil pattern, secondly the injector placement seems to be compromised by the inlet manifold design.
the injectors in the m20 seem to fire at the floor of the port rather than down the port, this is either due to the positioning and angle mandated by the inlet runners curving up (think fitting/service) or is an attempt to get the fuel atomised via air flow or heat before it enters the chamber, as after all that beam blowing in un hampered would make a mess of the mixtures... well.. mixture.
the ideal in this circumstance would be a multi hole injector with a very fine spray pattern aiming as directly at the back of the valve as is practical, funny how this seems to be the case in more modern designs.
when the m52 injector is put into this equation we have two look at two things, (well three by im disregarding impedance) its flow rate and its spray pattern.
the spray pattern of the 4 hole type 2 bosch injector is as quite rightly stated not the ideal situation for the m20.
it has been designed with a multi valve engine in mind, thus the spray pattern is more like a V shape.
now this initially sounds bad, but as said above a large quantity of the fuel from the m20 injector is aimed at the port floor and the m20 port is much larger and rounder at the point of injecton.
with out looking into the specifics nothing can be proven here but i would expect the m52 injector to end up depositing less or the same amount of fuel onto the port walls.
what it will do (obviously also assumed atm) is deposit it over a wider area and if some ends up higher up the sides it will be in a faster air stream.
this coupled with the fact the m52 injector produces a much better atomisation direct from the nozzle should result in the mixture quality that reaches the chamber actually being more homogeneous than when the m20 injector was doing the work.
so from those albeit assumed situations it would be safe to again assume that the engine will be able to mix up the fuel adequately and cope just fine.
this assumption is backed up by the m20 engines that are floating about with m50/52 injectors not only passing mot emissions tests fine but also reporting better drivability, improved torque and better economy, all no doubt due to better atomisation of the fuel and more controlled combustion as a result.
which leaves one big elephant in the room, the matter of the flow rate of the injector, now its no secret that the m50/52 injector is of a higher low rate to the m20, iirc its around 11%.
this is quite a bit, its going to have a not insignificant effect on the air/fuel ratio.
fuel injectors are just taps or valves for petrol, they have a flow rate which is rated in CC/min, now this is how many CCs of fuel can get past the injector at a given pressure in a designated time.
which is brilliant, as from that we can tell how much goes through in 1 second, (1/60th)
this allows the ecu to open an injector for a fraction of a second and get the precise amount of fuel needed for the air thats entering the engine at that moment.
which is brilliant provided the ecu knows both the mass of air getting past the valve, and the mass of fuel getting past the injector valve.
which means CHANGE EITHER OF THESE FACTORS AND YOU WILL HAVE AND ENGINE THAT IS NOT RUNNING CORRECTLY.
if you swap an injector out for one 11% bigger then the ecu has no way of knowing about this change and without recalibration the mixtures will be too rich.
now if we go back to the start we see that this is the situation the engine can deal with the least and is also a prime situation to end up with bore wash.
the lambda enabled motronic 1.3 may be able to cope with this but its not an ideal method.
remapping will prevent this situation 100% and is the correct thing to do.
(the same thought apply to fudging things with different air flow meters and hoping things will be all right with no calibration.)
now in summery, yes the spray pattern is not ideal but it is far more likely that a rich condition and lack of calibration is the culprit for any bore wash that has been experienced in the past by people using m50/52 injectors in an m20.
tbh the 4 hole injectors are old news now and engined like the duratec are using denso 12 hole designs which are as much of a leap ahead as the 4 hole is over the m20 injector.
we really should be talking about other injectors by now.
mpereznoble
Fri Jan 20, 2012 11:17 pm
Do M50`s (be b20,b25) inyectors work good with a m20b20? Any chance of improving something¿?
HairyScreech
Sat Jan 21, 2012 2:52 am
the 2l is not really worth messing with, the answer to cheap na power is to start with the largest practical version of your engine, which in the case of the m20 for most people is either a 2.5 or 2.8.
you can make the pretty much the same alterations to a 2l as you can to a 2.5, you will just get less of a gain from it, in terms of injectors and throttles etc you will also need to size them for the smaller capacity, this means that nearly all of the m50 injectors will have too much flow for what you need.
Sat Jan 21, 2012 9:31 am
Excellent explanation, even though im 2 months late :D
