hi, was just wondering if anyone could help me with the vacuum lines from the intake manifold on a PFL e30 m20b23 euro spec it seems like its been played with as there are lines witch aren't even hooked up to anything, also it seems to a lot more lines coming off the manifold then most engine pics on here is that because they are motronic ?
Can post pics if it will help
m20b23
toby
Have you tried tapping your chassis number into the parts catalogue listed in 'Technical Help'?
(which is a better place for answers to your thread too
Tap the last 7 digits of your chassis or look at the right spec and age of vehicle
Catalogue here - http://www.realoem.com/bmw/select.do?kind=P&arch=1
It may show you the routing
like here
http://www.realoem.com/bmw/showparts.do ... g=11&fg=45
this is based on a 1986 323i
like here
