fuel pumps 320 and 325i
mk1nuts
Post Tue May 17, 2011 5:52 pm
are they pretty much the same ??
as i bloody need one aswell as a sender unit !!!! argh!
cheers guys :cool:
mk1nuts
Post Tue May 17, 2011 11:25 pm
ideal mate thank you!!
DmcL
Post Thu May 19, 2011 3:21 pm
FYI fuel injectors are also the same.. the only difference is the fuel pressure regulator. 320i had a 2.5 bar reg and 325i had a 3 bar reg.
WMMotorsports
mk1nuts
Post Fri May 20, 2011 12:07 pm
thank you very much buddy :)
VW-will
Post Sat May 21, 2011 4:30 am
If that's the case with the injectors, why doo Bosch coulor them different? Usually means different from Bosch doesn't it ?
Post Sat May 21, 2011 2:10 pm
320 and 325 have different rail pressures, but the injectors are different as well.
