M20 rebuild
savy
Hi guys, ive stripped the engine apart in order to do a full rebuild took the block to my local engine machinist and he said i need to rebore the block and need larger pistons. Wondering if i should go ahead with this? what would be the my best option and how i would go about doing this?
e301988325i
make a 2.9 with oversize pistons £2,000 I'd say, or buy a s/hand engine if you're on a budget.
You're savvy enough to strip an engine, did the bores actually look bad?
I said:
e30topless said:
lock the wife in there
Gunni
What are your plans with this engine?
my reccomendation is get another bottom end with no issues. It´ll be cheaper on all accounts.
savy
Bores were not to bad slight scoring, and all the pistons were heavily scored. The plan was to just rebuild and freshen up the engine i.e. new shells etc. Before stripping the engine it used to make a slight knock on idle and would disappear at 2,500rpm when revved. Engines is from a 1987 Tech-1 (High compression). what would be the wisest option?
- **BANNED**
Hi-comp pisons are the valueble bits,and they are buggered!
If you are desperate to keep the engine number,then re-bore and new pistons is the only way,in this instance it would be an idea to research the big over-bore mentioned above.
If it's more a case of getting the thing running at a cost effective rate,then follow gunni's advice.
M20 is not a cheap engine to re-build,so the option of a decent,complete and heard running s/h unit should also be considered.
Youth is wasted on the young.
78gizmo
Got a good complete high comp 2.5 here for £150 if you need a cheap option?savy wrote:Bores were not to bad slight scoring, and all the pistons were heavily scored. The plan was to just rebuild and freshen up the engine i.e. new shells etc. Before stripping the engine it used to make a slight knock on idle and would disappear at 2,500rpm when revved. Engines is from a 1987 Tech-1 (High compression). what would be the wisest option?
