What blocks this?
GovR
Post Sat Apr 02, 2011 9:31 pm
Hello zoners!
Im abit confused with what spec my engine is as I am researching on how my engine would be converted into a 2.7.
I understand I have a b25 head - but cant work out what the block is as ive searched for 27K89 and cant find nothing.?
Heres the pic....
maggspower
Turbo Farmer Tractor Driver
Post Sat Apr 02, 2011 9:43 pm
Yes you have a 325i head, the engine code number is near the bottom of the dipstick on a machined flat area.
maggspower
Post Sat Apr 02, 2011 9:46 pm
Having said that the crank could have been changed. The only sure way is to whip the sump off and check
GovR
Post Sat Apr 02, 2011 9:54 pm
Cheers for the pointer - Il have a look in the morning.
I just got confused thinking the 27K89 meant it was a 2.7 eta bottom end which I highly doubted after looking at the wiki guide of building a 2.7 as it points out it uses 27 6KA.
Whipping the sump off would mean draining the oil :(
HairyScreech
Post Tue Apr 05, 2011 9:45 am
thats not the engine number, the engine number is next to the sump, below cylinder number 2, inlet side.
