hi im thinking of putting carbs on my 2.5 m20, but i dont know anything about them, is it a big job? where can they be got, does the ecu need to be modified? any bhp gains?
any help much appricated thanks!
m20 carbs
fowler
- Boost Junkie
Speak to OAKEY on here he has done it i think he may be selling the setup as next stage of his project.
EX A-Tech Workshop bitch !!!
gone but not forgotten
Mikey_Boy
e21Jason
Been there seen done more than once
If you do not know any thing about why do you want to put them on your car
There onloy two reasons to run carbs
you are limited my race series regs and have either the choice of stock unmodified ecu or carbs
the second reason is they sound good but 200bhp e30 on stock efi with be better to drive an probably faster to low down tractability than a the same car making 200bhp on carbs
Jason
Jason
BMW e21 track car supercharged s14 cage and fabrication by www.chizfab.com
Z3M Coupe for sale
69 Alfa spyder
Z3M Coupe for sale
69 Alfa spyder
AlpineAde
You could also have a word with a member on here: dcoeinside. He runs a stroker track car with triple Webers. He also has an excellent Youtube channel you could contact him on.
MillRat
Hard work.
Find yourself an already carburetted car (like an E21 320/6 or an early 4 cylinder E30) and upgrade the carbie setup on that.
Hardest problem with a carburetted RHD E30 is that the rear carby fowls on the brake booster (that is if you are running triple sidedrafts, which of course you would do on an M20).
Cheers,
Michael.
