What turbo do I have?
Lawone
Post Fri Sep 24, 2010 10:04 am
Hey..
Trying to workout if i can use this turbo on a E30.
Information i have so far.
on the exhaust housing.
Garrett
M4
TAG PLATE ( TT 2G0IX)
DHSGNI
GIL5
on the inlet housing.
AiResearch
A/R 48
M27
8SC
this is all i can see at the moment.
But i kinda would like to know what it is.. and if it be a good setup for a e30 325
Photos Uploaded!
Image Image Image Image Image
maxfield
Post Fri Sep 24, 2010 10:07 am
Looks like a turbo from a Ford RSTurbo, Oh which I believe is a T2 as a lot of people convert them to T3.
Lawone
Post Fri Sep 24, 2010 10:15 am
ahhhh.. okay. would this be a set-up worth chasing?
Mikey_Boy
Post Fri Sep 24, 2010 12:24 pm
It does look Escort RS turbo-ish... Had a look at the pics and given that it has a Turbo technics label on it makes me wonder if it's off something else (as the compressor housing orientation looks wrong for an Escort and it certainly isn't Cosworth size or shape!) or maybe been re-built by them. Might be worth giving them a call:
http://www.turbotechnics.com/contactus.htm
They should be able to shed some light on it. If so, then you should also be able to get a compressor map to see what airflow it can tolerate before it starts choking or stalling.
If it is a T2, then it's going to be screaming it's nuts off at about 240hp so it might be worth looking at something bigger to flow more air? Turbo matching is a balance of exhaust turbine spool up versus compressor airflow so trial and error isn't going to be a good thing!!
Cheers,
Mikey_Boy
Gunni
Post Fri Sep 24, 2010 12:28 pm
T2 will never work nicely on any bmw engine.
Gunni
@ 2012 VEMS group buy !!
Lawone
Post Fri Sep 24, 2010 12:34 pm
Thanks for information..
I contacted Turbo Technics a while ago.. regarding the turbo.. they required the model number.. but all mine has is TT, after i told them that.. they never got back to me.. I may blast them a call in regards to it.
only 240hp? blimey not really good for much then lol.
Hopefully I can get more out of Turbo Technics.. As even if i don't use the turbo.. at least when i come to sell it i know what im selling..
Will update once i get a response from TurboTechnics
Green
Post Sat Sep 25, 2010 2:57 am
As i recall the RS turbo escorts are actually t3's and the fiesta's use t2's as when I had my fiesta I straight swapped a t3 from an rst escort onto it.
Does look the same size as my t3 though.
Found a pic off my facebook, as you do
both are t3's
ross2009
Post Wed Oct 27, 2010 7:39 pm
yeah escort rs uses a t3 fiestas actually use a t25 but it aint either of them coz the exhaust housing is totally wrong on both escorts and fiesta they have a 90 degree neck faceing the ground
where as the sierra cossie has a straight 3 bolt exhaust housing like that picture
when they dont the escort cossie they made a large turbo model and a small turbo model i believe that turbo it from a small turbo escort cossie
