2.5 injectors
xedan
my friend has got 3 2.5 m20 engines 1 standard 1 modified and 1 stroked to a 2.7 but each engine has diffrent coloured injectors the colours are white,yellow and blue what 1's would be best for a cammed and chipped and would any of these be suitible for a turbo'd m20
fowler
- Boost Junkie
they are all too small do not flow enough you need to a minumim of 32lbshr for a m20 turbo even for a low boost set-up
are you trying to build one ?
EX A-Tech Workshop bitch !!!
gone but not forgotten
xedan
my friends looking to build a turbo'd m20 he has already got a turbo kit from usa but is looking at management etc . he is also thinking of low comp pistons so he can run more boost but its still all in the early stages collecting bits etc
DmcL
all those injectors are probably the same or very similar flow rating.
u can run a 7-8psi setup on 24lb injectors, ive actually got a tune here for an M20B25 running 7-8psi and on 24lb squirties with a 173/380 ECU.
WMMotorsports
