Bore out 320i block
Coyote_ar
Post Thu Jan 28, 2010 9:52 am
Hey guys, i want to know if my block is one of the older 320i blocks you can bore out to 84mm.
From the numbers on the side, i can tell it was made on 1983.
Here are some pics of the bores and water passages.
If you cant tell by the pictures, can someone tell me where i should take some measurements in order to tell if the walls are thick enough?
How far can i go before the walls are too thin?
Cheers.
tomson
Post Mon Mar 08, 2010 2:43 pm
I was under the impression any 80mm 320i block could be bored the the 325i's 84mm.
As for measuring you could use a digital vernier caliper to take a measurement of wall thickness between cylinders. Then you can work out what you will be left with after -4mm.
goosiegander
Zonegoose
Post Mon Mar 08, 2010 8:04 pm
My 2.8 is a bored out 320 block to 84mm,
No issues :D
Chris
Post Fri Apr 30, 2010 4:17 pm
Would 86mm take the average block too thin?
And would that put you in the realms of custom head gaskets?
Chris
