firstly no ports have multi angle valve seats yet, which are worth 15% to 25% of the remaining loss, so thats the next task before going for big valves.
also important to remember this is flow per mm lift, and a stock 325 cam only goes to 10.3mm and a valve really shouldnt flow much better after its lifted 35% of its diameter. (port area to curtain area relation ship thing.)
stock intake (885)
stock exhaust (885)
best porting so far (885)
alpina intake (885)
alpina exhaust (885)
stock 320 intake (731)
320 intake with 42mm valve and throat from a 885 and opened up to work with valve (731)
duratec ka 1.3 intake for comparison
theoretical potential maximum for a 42mm valve.
conclusion, the 731 head port is shaped to work with lower lift, as expected increasing the valve size on the 731 increases the flow proportionally through out the range as is the expected convention. flow curve remains the same as that is largely dictated by the geometry of the port, valve seats and the chamber.
a 731 with 42mm valves and a bit of porting to work with them is better than a stock 885 head for an engine with a stock cam, but the 885 with work shows it the way home.
why havent i beat the alpina head yet? multi angle seats.
