I have the E30 M20B20, Motronic 1.0 Basic 027
My car starts only with the temperature sensor off for the ECU and operates on a very rich mixture of fuel and air.
If I connect the plug to the temperature sensor, the machine stalls. If I start the car with the temperature sensor connected, it will raise the engine speed to 2000 rpm for a second and stall.
I replaced the temperature sensor for the ECU, the temperature sensor on the dashboard, the crankshaft sensor, the speed sensor, the idle speed regulator, the air flow sensor. I checked the wires on the coolant sensor-all right.
