Hello,
I need help with some info.
I just rebuild my engine and now tried to start but engine can not turn on.
It is likely turn on a few second but then die and after that it won't start again.
There is spark at all sparkplugs, and there is a fuel at all injectors, so I think dme and cps is normal?
Injectors all firing fuel.
Does is it because the engine dead top is not in position?
Please help me what should I do
Thank you
Markus
It now run after I set the gap between cps with tooth 0.25mm
Sorry to write in the same first thread because the website not allowed me to reply, I don't know why
@tiggerfish
Thank you. It is not mixed as I have give it a label.
It run now but with full open throttle, I don't know why may be the engine still new so it need a few time to running in? As all parts still rough?
No star after engine rebuilt
- TriggerFish
Stupid suggestion, but it caught me out...
Are the tps and ICV plugged into the correct plugs? I got them mixed up, and it would start for a bit, then cut out immediately.
