Hi I'm building a 2.8 m20 and was planning on using stock m20b25 injectors with a refurb. But reading more people are using the m30 injectors. Has anyone done both of these and have pros and cons of both. Also is the any other injectors you would recommend m50/52.
Cheers gav
M20b28 injectors
Mjne has standard 2.5 injectors,ecu and 320 afm It has loads of torque,revs out to the red and is a lovely drive.I believe it has a standard cam so if you use a high lift one you may need more fuel. Mine is an auto cab and i just wanted more low to midrange torque which it has
