M20B25 rebuild suggestions
Synysterkyle
Wed May 16, 2012 10:57 am
Hi all, I've just got a spare m20 engine from an automatic, it's done around 90k I believe. The plan is to whack it on a stand and slowly rebuild it, get the bits powdercoated etc.
First off will this engine fit in my manual m20b25 ? They're both chromies.
Another thing, is there anything worth uprating/modifying while it's in pieces ?. I read something about shaving the piston rods down to save weight. Is there any little things like that I could do ?. I'd love to turbo it if I come across a bargain but that might have to wait.
It's going to be the first engine I've had completely in bits so should be a learning curve !
Any advice is appreciated, cheers
HairyScreech
Wed May 16, 2012 1:06 pm
yep, should fit no trouble but may need a new pilot bearing in the fly wheel.
Wed May 16, 2012 1:11 pm
As above, spigot bearing at end of crankshaft may be different.
It may be worth converting to later Motronic 1.3, as the early chromey 325i had Motronic 1.1 which has a flywheel sensor. The little metal peg tends to fall out of the flywheel, then it won't start, and it's an engine/gearbox-out job to replace!
Motronic 1.3 is more reliable, gives better driveability and easier to chip.
Synysterkyle
Wed May 16, 2012 1:19 pm
Great thought might be the case !
I'll have to have a read up on the motronic 1.3, I'm guessing it's a case of swapping the loom and ecu ?.
Wed May 16, 2012 1:24 pm
Yes, I believe that is the case - do a search on here, as some people have done this conversion.
Here's one example:
http://www.e30zone.net/modules.php?name ... 78&start=0
Or you could do a Megasquirt conversion - see the Zone Wiki for a guide.
Eddie25
Wed May 16, 2012 1:37 pm
Cam and 6 branch :twisted:
Really makes an M20 come alive.
Rust is lighter than carbon fibre.
Synysterkyle
Wed May 16, 2012 6:39 pm
Speedtouch wrote:Yes, I believe that is the case - do a search on here, as some people have done this conversion.
Here's one example:
Mines an 86' so i'm guessing its the Motronic ML1.0 ? from what I can tell from the wiki.
Looks like i'll need all the bits, CKP sensor, Oil level sender, ecu etc.
Megasquirt is quite pricey though isn't it ? Probably be cheaper picking up the loom etc from a car being broken
Eddie25 wrote: Cam and 6 branch :twisted:
My car has a chip at the minute apparently and was told a bigger bore TB and 6 branch would push it to 200bhp according to the previous owner anyway. Any suggestions on a 6 branch ? and i'm guessing the cam would be an aftermarket one ?
Wed May 16, 2012 10:12 pm
Yes, yours is probably ML1.0 or M1.1 - M1.3 came in with the mid-1988 (E/F-reg onwards).
Megasquirt can be built quite cheaply if you're handy with a soldering iron; see Flappysocks' site www.diyefi.co.uk
You'll struggle to get an M20B25 to crack the 200bhp barrier - most 2.7s don't quite make that.
The BTB is the best six-branch, but they are expensive. A Hot-tuning one for £200 is OK, but don't expect much gain.
Synysterkyle
Sat May 19, 2012 10:12 am
I'll have to find out prices for the megasquirt, i've always liked the idea of it, was planning on having it in my old golf but never went big turbo in the end.
When people mention cams, are they lightened aftermarket ones or just standards skimmed down ?
Don't suppose there are any guides or threads on completely overhauling the m20 ?
Andyboy
Alpina Colada
Thu May 24, 2012 8:54 am
Forget mega squirt, more aggro than it's worth. Moronic 1.3 properly mapped is just fine.
Synysterkyle
Thu May 24, 2012 9:16 am
Someone on here has advertised all the bits for the motronic 1.3 conversion so im going to go for that, saves me sourcing all the bits seperatly !
Thu May 24, 2012 11:29 am
Good move - a very worthwhile conversion. PM sent.
Synysterkyle
Fri Jun 01, 2012 10:47 am
Found a handy link for rebuild parts
http://e30performance.info/viewtopic.php?f=21&t=269
Engine stand arrived today so should be making a start on this soon !
