b25 with 320i gearbox, what clutch
Tue Nov 29, 2011 8:31 pm
sorry if its a dumb quation but If i'am using a 325i engine with 320i gearbox what clutch do i need
a 325i one or 320i ????
sweep
Tue Nov 29, 2011 8:32 pm
either alex
Tue Nov 29, 2011 8:36 pm
Good stuff
Tue Nov 29, 2011 9:08 pm
i have a half decent looking clutch here with pressure plate and a standard 6-pot fly wheel winkeye
Tue Nov 29, 2011 9:12 pm
ummmm..... pm on its way
Tue Nov 29, 2011 11:12 pm
Flywheel, clutch disc and release bearing are the same part number for both engines. The cover plates have different part numbers, which I suspect is a stronger spring in the 325, given the noticeably heavier clutch pedal in a 325 compared to a 320.
Wed Nov 30, 2011 7:21 pm
Brianmoooore wrote:Flywheel, clutch disc and release bearing are the same part number for both engines. The cover plates have different part numbers, which I suspect is a stronger spring in the 325, given the noticeably heavier clutch pedal in a 325 compared to a 320.
given that a lighter clutch is nicer i vote for the 320i one :P
