Yay! I've finally finished reading this project from start to finish. I am so impressed by all the work and research that has gone into this, and especially by the fact that it's fitted to an M42 (since i have a 318iS
I'm totally lost when it comes to the theory of turbos or superchargers, or at least i was totally lost - now i feel i have a faint grasp on what goes on, so thanks for educating me
The only part i feel i can give any input on is the laminovas - which are looking very cool!!
You mentioned that the SC output area is 37sqcm, the fin gaps are 64+sqcm, and the slots are 58sqcm. But the fins sit up against the gaps, and are 1.8mm fins / 1.8mm gaps (ie. 50/50 fin/gap) so forget the 64sqcm figure, the actual gap for the air to flow is half the slot area, 29sqcm. Add to that the fact that one big gap flows better than lots of small gaps, and i think you are adding in a fair bit of restriction there.
CraigG's point about volume flow being more important than contact time is only valid when using the airflow to cool the liquid in the laminova (ie temp change of the air is unimportant), but in this case you are cooling the air, therefore high volume flow in the cooling liquid is important and air contact time is important.
Personally, i would increase the area of the slots - a blocked area over the point the laminovas meet each other and the top and bottom edges is good since it prevents air flowing through without "touching" the fins at all, but it doesn't matter that the air flows near the end of the fins - infact it's probably better since you are setting up a temperature gradient in the direction of fintip -> core, rather than fintip <- midfin -> core (hope that makes sense). Also giving more flow area will decrease the speed the air has to flow over the laminovas, increase contact time, and give better cooling.
Sorry if i'm teaching my grandmother to suck eggs here, but thought it might help - as i said, this is the ONLY part of the project i actually have any knowledge of so if it doesn't fit with the rest of SC theory then ignore me and call me a muppet
Well done anyway, and errrr, if you feel the need to repeat the project for some reason, i have a willing engine
Simon
