On with a bit more building then, shall we...........
More clearance issues to be dealt with. This time the conrods run into the lower part of the bore, so this was relieved to allow them to pass. This can be seen on the inside of the crank case.
The next job was sorting out the rings, the pistons came with a conventional set, plain, napier second, and sprung oil control.
Being custom made, the rings need to be filed to fit the bore. This can be a long process of taking the ring in and out of the bore, measuring and filing, the rings can be quite fragile, and you only have one chance to get it right. It can take a while, The top and second both need to be done.
To aid this I made a ring squaring tool out of a lump of nylon for this bore size. You put the ring in the bore........
Then push it down with this, that way the its in there square and the end gap can be checked with feeler gauges.
The rings start having a cross over within the bore, the gap corresponds to a formula using piston diameter as its variable.
This is the type of ring file I have used for years.
I have never really liked it, its slow, also inaccurate i feel, and at the time its abrasive diamond wheel had seen better days. So one of the twelve rings was gapped, then on the second one................ ummmmmm, this happened
It was a strange feeling, initially, I laughed, then had a Basil Fawlty moment..... Ring filer went out the window, never to be used again
Then it dawned on me, these rings are from the USA.......... The car is in the rollers in three weeks
So, I set about designing a new filer, one I was happy with, an electric one
This design and making process did not get far, as I looked over and saw the abrasive wheel on the valve grinder, so I tried it out......... I'm doing the left hand bit of the ring here, the other side is not touching the wheel.
It worked perfectly, I was worried about keeping the ends of the ring square, but its not an issue. Its much faster, more controlable, and needs less pressure applied.
Just needed to remove the burr with a very small hand file.
This left me with 11 perfectly filed rings, a piston ring in America, and three weeks to finish building, fit, and run in an engine........................
Can it be done....... Find out in the next episode
I am confident the busted ring was a fault within it by the way. My story and I'm sticking to it
