Suspension
RJD131267
Post Fri Jul 19, 2019 1:04 pm
Hi, I've only just joined the E30 Zone and finding my way around. I have a 1991 325i SE Auto (2 door) and am trying to locate new Bilstein B4 struts and inserts, but I believe the actual struts are no longer produced. The strut diameter is 51mm. Can anyone help me?
Many thanks.
Rob.
RJD131267
Post Fri Jul 19, 2019 1:42 pm
I have been recommended to contact Peter Walsh, can anyone help?
Post Fri Jul 19, 2019 1:53 pm
Hi Rob and welcome to the zone mate .
Stick around and someone will be along to give you some advice .
RJD131267
Post Fri Jul 19, 2019 2:15 pm
Cheers Mart, much appreciated.
stones
Post Fri Jul 19, 2019 3:09 pm
B4 front inserts and rear dampers are available on ebay. You already have 51mm front struts you just need to strip them down and replace the worn out parts and give them some paint.
HTH
Post Fri Jul 19, 2019 6:09 pm
HTH
Doe`s this help ?
RJD131267
Post Wed Jul 31, 2019 9:54 am
Many thanks, got the inserts etc and springs. All fitted and much better.
