Does anyone know anywhere in Scotland, preferably Glasgow or Inverness area but anything reasonably close will do, where I could get my car noise tested before I start taking it to track days? Or will the old Maplin special do fine and be accurate enough?
Thanks in advance
Ciaran
Sound Meter
cecotto_singh
i used the maplin one and then took it back and got a refund! did the trick!
march109
Just remember it should be tested at 1 metre from the exhaust tip and at a 90 degree angle (or 45 can't remember) from the tail pipe, ie. don't point it directly at the tail pipe. Different places have different specs on the engine speed during the test, some do idle some do drive by, so check with the venue first, or someones whos been there and had there car tested.
