lsd
salami
I have a 3.91 standard diff on my 325 and wanted a lsd in the same ratio but no one has one what is the next size im not too bothered on topend but do want excelleration?????
87 325i
Scruffymurphy
The 3.91 LSD is pretty common. You should be able to get one. I would hold out a while longer.
The next option would be a 3.73 but they are rare. A 4.10 would not suit 325.
salami
ok
thanks no rush for it so i can wait a while
87 325i
oldroydsr4
Check out link below
The slipper you are looking for.
http://www.e30zone.net/modules.php?name ... sc&start=0
salami
Thanks oldroydsr4 i had seen this too,a bit far for me i think
87 325i
Beemer Redeemer
We have one in stock. Still in the car and can be tested by the customer if needed.salami wrote:I have a 3.91 standard diff on my 325 and wanted a lsd in the same ratio but no one has one what is the next size im not too bothered on topend but do want excelleration?????
#280 + vat
(P&P #19.95 if needed)
James
01179 860 635
tomstickland
I'm looking for an LSD for my 318iS. Can somone point me to any articles concerning the various ratios?
Ideally I want the small case unit that was fitted to the 318iS, and I'm considering sourcing one from the USA.
From a bit of searching, looks like the iS had 3.91 or 4.1.
What was in the 325 sport and the M3?
Scruffymurphy
The 4.10 is best suited to the IS.tomstickland wrote:I'm looking for an LSD for my 318iS. Can somone point me to any articles concerning the various ratios?
The Sport had either a 3.64 or 3.73
I'm not sure about the M3 3.25 maybe
tomstickland
Thanks.
I just found this article, which is quite useful http://www.esatclear.ie/~bpurcell/318ismods.html
For the 318is, I would stick to 4.10 for a stock setup, although the 3.91 will not effect it too much - but the 3.91 ratio is ideal if the engine has been modified. Usual sources are the US E30 M3 (4.10), the European 325i Sport (3.91) or any 318i/is fitted with a LSD.
Lloydie38
I bought a 3:64 from Jonb for £250. Had it over a year on the track girl and sweet as, made a real difference to the sideways moments
BadDave
If you buy it on monday,It'll be delivered by ThursdayBeemer Redeemer wrote: We have one in stock. Still in the car and can be tested by the customer if needed.
#280 + vat
James
01179 860 635
BadDave
I've just recently bought one fron Redeemer Beemer (listed on Ebay)
Had been sandblasted/painted/new seals/gaskets etc
Even came with 2 litres of diff oil
Can recommend him for fast service
Dave
Dave
sam325is
i've got one 3:91 £250 from a 1990 tech 2 sport can be seen fitted and working on the car if requested
agreen
so will these be a straight fi on a 318is?but the 3.91 ratio is ideal if the engine has been modified
salami
Thanks for the offer but im going to put off the lsd for a few months and get a roll cage insteadsam325is wrote:i've got one 3:91 £250 from a 1990 tech 2 sport can be seen fitted and working on the car if requested
87 325i
oldroydsr4
Personally the LSD was the single most enjoyable modification i have made to an e30.
salami
a lsd was the first thing on my list but it wont do me any good when im upside down wishing i had the cage
just have to wait a few months
have you used yours on track?did it make much difference?
87 325i
