I am building a road rally car and i am in the process of removing the sunroof, what do you guys usually do with the sunroof?
I have noticed it is very heavy!
What do you think of making a fibreglass mould from the original one then glueing that in??
I am pretty sure i can do it very easily......
Removing the sunroof
Beemer Redeemer
Remove the whole thing, sunroof cartridge, mech and carrier (almost size and shape of the roof panel itself).
Then you've got a few options;
* You could remove the roof skin completely and buy a non-sunroof skin from BMW (about £220). Thats the option ive gone for. BUT it is a serious PITA, time consuming and something you'll get half way through and think, why the fuck did i start this.
* You could keep the actual metal panel and weld some brackets to hold that in. Then seal up around the edges inside and out.
* or could make some sort of fiberglass panel, but metal sheet would probably be more adequate. You could simply apply sealer underneath, then pop rivet it to the roof panel (obviously overlapping the sunroof hole.)
Depends how much time & budget you have or whether you care what it looks like or if you just want it functional.
James
James
Lloydie38
Cheep option....
See Below - Cheap but roof inside and out looks cr@p if I'm honest
[img][img]http://i142.photobucket.com/albums/r117 ... emoved.jpg[/img][/img]
[img][img]http://i142.photobucket.com/albums/r117 ... tedish.jpg[/img][/img]
ed325i
I am going to use a bit of POLYCARBONATE and seal that into the hole.
alan1272
Trise30rally
According to the msa book it has to be metal, as my original skin is completely rotton i need a new sunroof, i checked ca automotive and they are £120!
Does anyone know of one going spare that will post?
A1BMW325iSport
i did have a mint sunroof somewhere but like most things will be buried in the shed lol
