Bucket Seat and harness, and mounting
1an
im looking at getting myself a pair of cobra suzuka seats hopefully through the zone discount, (illl try to get in contact with cobra on monday to see if it is viable)
basically i need to know how to mount them, obviously they are side mounted, can they be mounted straight onto the orginal mounting points of my seats or do i need to also buy the subframes aswell for each side?
harness's,
need to be suitable for on the track and for some drifting aswell, not bothered about practicality.
what does any body recomend? ive been looking at the luke 4 point harness and also sabelt but they seem to be very expensive, im wantign 4 points in both sides of the car, also need to be able to be fitted to a cage aswell in the future,
also whats the best place to mount the harness aswell bareing in mind it wont be on a cage to start with?
and before anybodyu says anything about my car only being a 1.6 i dont really want an opinion,
cheers ian
harness's,
cheers ian
agreen
you dont likethe monacos then ?
Cabrio
Suzuka will need side mounts but can get runners from Cobra and can get from different suppliers...as an unofficial trader dont know if I can recommend myself!!
1an
agreen
do you have a pic f the ones youare gonna get then or a link ?
1an
http://www.cobraseats.com/suzukas.htm
they just seem to be a much better seat, more supportive aswell but they are also alot more £'s.
another question i have it will i still sit fairly low in the car with the seat fitted? as i like to sit nice and low in the car.
agent006
Monaco:
Suzuka
No contest really. I tried the Monaco at DT when i was looking and found it to be really poor quality and obviously a cheap design. Went for an OMP RS in the end.
Suzuka
agreen
so ow much can we expect to pay for these with the zone discount as i am now thinking of not buying monacos and getting these intead !
1an
Cabrio
Cobra have dealers throughout the UK and not all are listed on the site...let me know if want any dealer details as do have contacts cheers
1an
fuzzy
the harnesses will mount to the existing seat belt point at 1 side ,you might need to bolt a mounting point through the floor at the other side.the rears will mount to the rear seat belt mounting points if you have removed your rear seats. im sure it was sabelt 4 pointers that i had in my last project and they were quite cheap at about £40 each.iirc i bolted the 2 rear brackets together in the one mounting point on each seat.the monaco seats are a cheap entry level bucket seat but were adequate for the job although hard and uncomfy but they saved me in the heavy crash that i had
i bought custom fit cobra adjustable mounts that didnt actually fit
schuey
It will be better when you have a cage to get one with harness bars such as the saftey devices cage,that way the harnesse are at shouder level. If you mount them on the floor you can cause a pretty severe back injury in a crash. I had mine mounted on the rear shelf by drilling holes for the eye bolts and fitting a reinforcement plate underneath.
Agree with the suzuka,I had monacos and they are crap.
318 IS. Sold.
1an
agent006
I've got Sabelt in mine, were something like £98 for 3 inch shoulder and 2 inch lap belts.
1an
fuzzy
arent the rear harness straps meant to be mounted between certain limits of angles? not to flat(parcel shelf) or not to steep(directly behind seat) for the best effect? iirc the quick release aircraft style buckle type are illegal for road use.
agent006
Think it's these, but not sure as i've had them for a while:
http://motorsport.demon-tweeks.co.uk/pr ... SAB901118E
I guess the cheaper ones aren't FIA approved?
1an
this is the problem i have mate, as i want to get it right untill i can sort a cage out, masybe halfway up the back of the seat back roughly with a spreader plate on the back? i dunno or maybe down where the original belt mounting points are roughly,fuzzy wrote:arent the rear harness straps meant to be mounted between certain limits of angles? not to flat(parcel shelf) or not to steep(directly behind seat) for the best effect? iirc the quick release aircraft style buckle type are illegal for road use.
and i read about the aircraft style being illegal.
fuzzy
i found the rear seat belt points at the back of the rear seat bench ideal for a 45 degree ish angle on the belts.
GuyM
just had my track car mot'd with 4 point harness and aircraft release and it did not come up as a problemfuzzy wrote: iirc the quick release aircraft style buckle type are illegal for road use.
have a look on here - there is bound to be something on it in here
http://www.motester.co.uk/
oldroydsr4
Monacos are not good at all, iv currently got corbeau evolutions and they are great in comparisson.
You can safety mount the harnesses on the rear seatbelt points but idealy off a rollcage.
1an, Buy the best harnesses you can afford, do you really want to skimp on the only safety item stopping your head going through the windscreen.
I'm using sabelt 4 pt and they are great.
shorty73
Scroth profi 2 clubman. FIA and msa approved with anti submarine. Can be upgraded to 5\6 point by buying the crutch straps. £85+ vat. GPR.
big_jof
- All the gear - no idea !
Got the sabelt 4 points (3inch tops / 2 inch lap) spot on.
Using the rear seatbelt mount points puts the angle just about on the limit for scrutineering (mines a 4dr) always passed but did get commented on a few times before I put the cage in.
Depending on the seat base you use theres spare mount points on the sill sides - some interior had a sport seat that needed the wider points - use this for one lap belt and I had the other side put through the tunnel. Didnt do this myself so it may need a reinforcer.
Seat wise if its not an every day car I put corbeau forza sports - fia approved - on bases from corbeau - got them for £175 including slider bases (sliders not fia but ok for sprints / trackdays when you've two different height drivers!).
Also good if your not exactly slim - my problem.
Got it all from demon thieves with a 10% discount for buying a pair!
This week I've mostly been on honeymoon!!!!
West yorks meet 2nd of each month near showcase Leeds PM or see meets and events.
JimmyC
Cobra SHOULD give you the deal on any seat, as I just PM'd Ian
They offer a specifically designed side mount for the e30, so id you order that aswell you can use the original mounting points
You will not get the seats any cheaper from any 3rd party, as the prices we pay are trade (slightly less on some items) so dont waste time shopping around ;)
The monacos are bloody uncomfy and not the best driving position, the suzuka looks the same as the evolution which is very comfy
Cobra also do some very nice harnesses, but they are not the cheapest, I run with sabelt 6 point harness 3 inch lap and 3 inch shoulder
1an
BadDave
Ian1an wrote:
harness's,
I've actually got a pr of blue Luke GM4's here doing nothing
They have the mounting eyes as well(which normally screw into the origanal seatbelt mounting points)
I also have a set(8) reinforcing points as well if that's any use to you
As Fuzzy said, they are supposed to be fitted at between 25deg and 50deg IIRC(somewhere about there anyways)
Can also advise you on how to make them work if/when you wish to fit them direct to the roll cage(easy mod/10 mins max)
Dave
1an
shorty73
Theres a maximum length that the harness straps are meant to be before crossing them. I don't cross mine as they are less than 20cm but longer than this I think they must be crossed.
1an
shorty73
M3Compact
I always mount my seats on sill/tunnel rails and I reckon it saved me from injury last weekend.
- Homo Hair
ouch!!
1an
shorty73
I can find lot's of pictures but no definitive reason why? I think that it's probably because the harness can spread along the harness bar of a roll cage if it's not crossed but can only get closer together if it is (hence the padding as a spacer). Probably irrelevant if your mounting to the floor. People are probably just copying what they've seen "'cos racers do it"
When you say you are using the original mounting points, do you mean for the rear seat belts? If you have eye bolts with clips then you can try crosed or un-crossed and see what you pefer. I've got a copy of track and race car at work with an article about harnesses in. Will try and dig it out.
