WANTED - 4/5 point harness
Theo
Post Sat Jul 21, 2007 10:02 am
Does anyone have a decent 4/5 point harness for sale which has shoulder straps which can be attached to the harness bar on the roll cage? Doesn't need to be in date, but should be in good condition.
BadDave
Post Sun Jul 22, 2007 8:44 pm
Got a pr of LUKE G MAX 4s in blue if your interested
Havn't been used much
Theo
Post Sun Jul 22, 2007 9:31 pm
Just won a 6 point harness of Ebay, so not urgent anymore. Out of interest, how do the shoulder straps on your harnesses attach to the rollbar?
BadDave
Post Sun Jul 22, 2007 9:49 pm
Currently they don't.
However
If you cut the stitching that forms the "stop" at the end of the webbing,you can then remove the existing attachment that clips into the eyebolt.
You can then feed it round the rollcage/rollbar and then feed it through the adjuster buckle.
If you want to make doubley sure that it won't come out of the adjuster buckle,you should stitch up the end of the webbing again.
Hope that makes some sense
Dave
Theo
Post Sun Jul 22, 2007 11:01 pm
Cheers Dave, that does make sense - I'm going to have a fiddle with this one i've bought. If I fuck it up I will give you a shout about your ones.
