fuel breather hose clearance with rear coilovers
gareth
Post Wed Jun 13, 2007 10:52 pm
does anyone else on here have 'true' coilovers on the rear? i've fitted my Leda coilovers but to get them to clear the fuel breather system (osr wheelarch) i've had to remove the coilover spring and keep the original pigtail spring for the time being.
does the breather system need to be removed? if so, how? will it make filling the tank a pain in the arse?!
JimmyC
Post Thu Jun 14, 2007 10:08 am
Yep happens on all sets I think, def LEDA and Gaz
Best way round it is to move the top mount holes out slightly and decrease the size of the spacers at the bottom by the same amount
Thats ho a large %age of the PBMW cars have been done
gareth
Post Thu Jun 14, 2007 7:22 pm
that would affect the strength of the top mount quite a bit i reckon and as mentioned before, the touring is heavier here already.
i've just heard from cosmo in the states and the rear half of their coilover kit (mounted on the original spring perches) is only $100!!! probably about £100 by the time i get one shipped here. winkeye
GermanGorilla
Post Thu Jun 14, 2007 9:33 pm
Hi,
The simple fix is to just re-route the plastic breather pipes.
If you trace them back you can even make the whole
arrangement a lot simplier without to much work.
Regards,
The Gorilla.
gareth
Post Thu Jun 14, 2007 9:48 pm
really? hmm, what about the fat rubber hose? i take it that's to throw fumes back out as you fill the tank?
where would i re-route to? the pipes go up a metal pipe that passes under the rear seat at present.
JimmyC
Post Fri Jun 15, 2007 9:45 am
gareth wrote:that would affect the strength of the top mount quite a bit i reckon and as mentioned before, the touring is heavier here already.
Wouldn't effect it at all, your not touching the tomp mount only the turret
Its a proven fix, on a number of PBMW cars and race m3's
Demlotcrew
Post Fri Jun 15, 2007 2:58 pm
GermanGorilla wrote:Hi,
Regards,
The Gorilla.
You beat me to it
Terryeds
Post Sat Jun 16, 2007 11:22 am
All you need to do is cut off the metal pipe that comes out into the wheelarch, blank it off, and then you need to extend the metal pipe inside the car a little so it comes out into the wheelarch further back, thus avoiding the coilover completely. It worked a treat on our M3 rally car!!
irishrally2006
Post Sat Jun 16, 2007 4:07 pm
terryeds sent you mail
gareth
Post Sun Jun 17, 2007 1:05 pm
maybe i need to define it a bit better :)
the shock top mounts are weak (known fact) but mine are stronger rose jointed affairs.
it's the mounting point on the shell that concerns me a bit more. these are known to be a bit weak (from what i've read) and extending the holes is a bit hairy imho.
gareth
Post Sun Jun 17, 2007 1:08 pm
Terryeds wrote:All you need to do is cut off the metal pipe that comes out into the wheelarch, blank it off, and then you need to extend the metal pipe inside the car a little so it comes out into the wheelarch further back, thus avoiding the coilover completely. It worked a treat on our M3 rally car!!
interesting! don't suppose you have any pics do you?
the possible problem with this idea is my car is a touring that's used with the seats up and down and ideally i want it looking totally standard from the inside and not have any extra pipework passing through the interior. i do have the extra panels in the rear of the touring that may well help hide it though...?
gareth
Post Tue Sep 11, 2007 12:27 pm
ok, it's time to revisit this as i've just found a hole in my tank so it's coming apart. this seems like the sensible time to get this sorted!
does anyone have any pics of what they've done?
is keeping the breather setup strictly necessary? it looks like an over complicated arrangement as i'm used to old cars that just have a tank vent pipe!
