How to mount harnesses with eyelets??
Hi guys, I'm putting 4 points in the car to go with the seats, I wont have a cage until later in the year, so they will have to mount with eyelets for now. Can anyone tell me the best way of mounting these, where to put the backing plate etc? car is an e30 2 door. Any pics of installations would be great to help me along.
With the back seat out there are two threaded nuts welded into the floor each side, which you can screw the eye bolts into for the shoulder belts. My subframes came with treaded nuts, one on each side to take eye bolts for the lap belts. But if the subframes don't have the provision for eye bolts then one can go in the hole that you take the bolt out of that holds the seat belt in place at the bottom of the b pillar and you will then possibly have to drill a couple of holes in the prop tunnel and use the backing plate under the car. If you need me to I can get some pics to you of mine.
Andy
Andy
JimmyC
- Contact:
If you cant mount harnesses properly ie to a harness bar I wouldn't use them, stick to the inertia belt with a glock thing
Personally I wouldn't trust the rear bulk head or parcel shelf holding up in a big smack
Just my 2ps
Just my 2ps
- Brian28
- Contact:
Both our race cars were done like that last season, a bit of flat bar behind the bulkhead and they were fine for scrutineering so although not as good as harness bars should be safe enough. A bigger advantage of harness bars is probably that there is a lot less belt stretch in the event of a spill rather than the security of the anchoring points. So given a choice I'd have harness bars, but still feel safe enough without them.
That high up mounting point on the rear bulkhead is asking for trouble if you ask me.... I've seen cars that have crashed not that hard and rip a 4" square plate through the floorpan of an e30!! Although low down isn't ideal, if you haven't got shoulder hight harness bars welded into a cage, I'd go with the belt original mounting points ... Jimmy C is correct.
Could you weld a bar between the C pillars just above the shelf, I've thought about doing that on mine so I could keep the back seat (I need it and haven't got a cage). I haven't stripped the covering off yet to see how strong they are, my bet is 'very'.
If it's just the strength of the spot welding on the bulkhead that's a concern, that's simple enough to fix surely.
jk
jk
E30 320i Rally Turd - Usually broken
E24 635Csi - Rotting in peace for now
E34 540i - Daily driver
Blown R1 Striker - In progress
I guess that's an option, but my concern with welding to the C pillars would be if the car is rolling or takes a hit on the C pillar, there's a strong likelihood it might affect the weld that's holding the bar your belts are attached to.
I don't think it's the spot welding I'd be concerned about as even if it's seam welded, it's the guage of steel used for the bulkhead is still the same.
Looking at that photo again, are those large rectangular pieces of steel aswell as the circular washers? I'd be more confident if they are and they were welded to the bulkhead.
