Make your own Coilovers!
DJ-325I
Thu Jan 04, 2007 2:54 pm
Hello all, has anyone made their own coilovers using the kit from demon tweeks or similar, where you weld on sleeves to the struts, if so do they work well and are they worth it?
m-dtech
Unapproved Trader caution
Thu Jan 04, 2007 10:21 pm
hmmm welding your own suspension......... ?
demon-tweeks
all sounds bad to me.
Brian28
Fri Jan 05, 2007 5:40 am
One of the guys in PBMW championship used these last year, best finish was third (twice) with consistent top tens. I'm going to be using them this year, if you're on a budget no better way to get height adjustable front suspension IMO. Coilover springs are realtively cheap compared to custom made standard shape ones so you can specify whatever lb/in you want and its not a huge cost to go harder/softer. I haven't been able to get any spring lb/in figures for most of the suspension kits that I've seen for sale, so not sure how these folks manage when they want to change if they don't know what their starting point is. There is a long thread on here somewhere about DIY coilovers if you want to waste 15 minutes of your life reading through it, but if I remember correctly most of it was ill informed comments and people having a pop at each other rather than anything useful or constructive. (Along the lines of the people at Gaz/Leda/H&R or whatever will be better welders than anybody else so any suspension that doesn't come from the bling factory must be rubbish and you are taking your life in your hands blah blah :roll: )
Brian
m-dtech
Fri Jan 05, 2007 5:43 am
i found something similar ;
http://www.e30zone.co.uk/modules.php?na ... ic&t=54410
not sure if thats what your on about ???
DJ-325I
Fri Jan 05, 2007 6:56 pm
sort of simlar to tht, apart frm it dosn't come with springs, jst the struts to weld on and the strut platform. but im nt sure on the size of e30 shocks.
http://www.demon-tweeks.com/products/Pr ... ode=RIX107
gareth
Fri Jan 05, 2007 9:45 pm
these are cheaper from Rally Design or Comp Brake. rally design can do the whole front setup including springs for £85 comp brake don't do the springs but if you get the springs from rally design you're looking at about £65 all in
if yoy get the spring rate or length a bit off, it'll only cost you £30 for a new pair! :D
this lot are fairly clued up on spring rates etc..... http://www.r3vlimited.com/
Andy335Touring
Sat Jan 06, 2007 9:27 pm
:thumb:
gareth
Sun Jan 07, 2007 10:05 am
Andy335Touring wrote:
:thumb:
they all seem to use the Ground Control kit over there which is afaik adjustable ride height front and rear :D
