suspension setup - for rallying / gravel
jono
Post Fri Dec 22, 2006 11:02 am
hello guys, i rally an e30 318is have coil overs fitted front and rear, spring rates 180lb / inch at front and back. I find that getting traction out of slow / tight corners is a problem, was going to try different ride hieghts / spring rates etc and wondered if anyone had any advice. Trouble I found when lowering back end is that a lot of negative camber is induced (and hence full width of tyre is not contacting road), was thinking of moding the beam has anyone tried this. Any comments would be grateful.
irishrally2006
Post Sat Dec 30, 2006 12:31 am
hey jono i am building m3 rallycar at the min. first event galway int. in feb. was going to use leda but got talking to goodspeed on here and i have used gp4 blistens coilovers. have used a 180lbs/220lbs spring in the back she sits down better for traction when u need it and still hard also. not sure if this any help but their it is.
Taffy
Post Sat Dec 30, 2006 10:45 am
Can't recommend Leda enough, cracking bit of kit for the money, you can buy adjustable camber/caster rear bushes that would probably sort that out
please contact admin with regard to sig
