cage
Hi
unable to PM for some reason but SD do a rear cage with X diagonal if that is what you ar looking for, it also has harness bars...depends on whether you have a sunroof or plan to keep it on current availability and price
Other option is a customcage which can also help you with
Hi you have lots of options but will depend upon your budget, how good you are for a welder, or know a friend:
BOLT IN - simpler if you dont or cant weld
The SafetyDevices E30 cage dealer could split a cage and the rear is as you require. the BOO9 Sunroof cage may not be available at this time need to check, the BOO7 non sunroof cage (is in stock)
OMP and Sparco also do bolt in cages but you will need to buy the whole cage and are for non sunroof cars, or need to remove sunroof case
WELD IN
OMP, Sparco, and a custom cage
Depends on budget but if cant obtain or afford SafetyDevices rear cage a custom weld in cage may be best option
Contact me with your contact details and will get someone to call
All depends on what you want to pay...
WELD IN
Have you an email ... as my pms dont seem to be enabled anymore, says I have done a script error!!!
Dont know how to post pics on forum but will research that also
Will take some pics of a BOO9 rear loosly assembled into a touring
gangster_massiv@hotmail.com, and na i dont know how to post pictures
