I'm looking to get some more power out of my 325i without having to fit a trick cam. Can anyone tell me if fitting uprated fuel injectors will help and where I could get them from (and would I need an uprated fuel pump to), or any other little tweaks that can be done for track days/sprints?
I'm new to the E30, but already hooked on 'em.
325i Fuel Injectors
bigger injectors will just flood ya engine and cause loads of grief longterm
stick with standard and get onto ant for a chip fella
and if funds allow get a big bore tb
www.oldskoolfantasy.co.uk
You'd be far better off fitting a Schrick cam, they're not that much if you talk to the right people! Any injector upgrade would only be any good if you are getting more air in to match and that means cams and remapping, you'd also need an adjustable fuel regulator,
please contact admin with regard to sig
the other thing to consider is having your current injectors sonic cleaned. I had it done to one of the race cars and it's quite suprising how much of a difference even that can make. If your injectors have done high mileage and never been cleaned, get it done. Then investigate the cams like Dom says.
Yeah good point Paul, we just had ours sonically cleaned, 2 of them were blocked and all 6 were out of balance, should give a few ponies back!
