bucket seats - my how to - if anyone is planning it
ollielsd
Tue Jun 06, 2006 8:10 pm
just finished off fitting a bucket seat in my e30 and thought id knock up a quick post to demonstrate what i did.
first off - meet betty
this is what many ppl will se when trying to figure how / where to mount a seat
you, ve got two m10 studs at the front and two m10 threads at the rear. what i did was make up two rail going left to right on the car with tubes welded in for the rear bolts to pass thru and machined "cups" for the front studs. After measuring the "square" made by the bolt holes in the seat runners, i measured it all up and welded machined bosses into the rails, with m8 studs for the rails
(sorry for the grind marks etc - they were dont in my lunch break!!)
the rail were then painted and bolted into the car
the seat runners were then loosely bolted down (NOTE: locking nuts - you dont want these coming loose!!)
and then finally the seat was bolted in to set the width of the runners and these were all tighten in. add harness and voila!
(sorry the pic is on its side!!!!)
any questions comments - please add - il be happy to help
Lloydie38
Tue Jun 06, 2006 9:05 pm
Nice job mate and the pics and info I'm sure will be of use to somone in the near future.
I did without the frame and just adjusted the standard frame that attachs to the seat and then straight onto the standard floor fittings. You sit lower but for the track it's in a really good low driving position.
Pic of my seats is on my site iyi.
Ian
JimmyC
Wed Jun 07, 2006 1:47 pm
Cobra do an E30 set of side mounts, bolt straight in
developed for the PBMW cars
ollielsd
Wed Jun 07, 2006 5:57 pm
JimmyC wrote:Cobra do an E30 set of side mounts, bolt straight in
lol i dont wanna pay for 'owt!
agent006
Wed Jun 07, 2006 6:36 pm
Surely the seat would be in the wrong place? Or do they have miltiple holes to allow forward/back adjustment?
calder
Wed Jun 07, 2006 7:06 pm
yep that's it, they have multiple holes to allow forward/back adjustment and the usual holes to allow some height and forward/back tilt. The difference with the custom E30 mounts is that they are wider on the base to meet the E30 seat mount holes and studs
calder
Rizzo
Wed Jun 21, 2006 3:06 pm
As far as I know Cobra don't make them anymore. Does anyone have a set? I would be interested. Cheers!
JimmyC
Wed Jun 21, 2006 5:12 pm
I have to call Cobra tomorrow anyway so will ask Marc about them for you, they do do them but dont carry stock and you cant buy them anywhere as they are not an official line ;)
Rizzo
Thu Jun 22, 2006 2:15 pm
JimmyC wrote:I have to call Cobra tomorrow anyway so will ask Marc about them for you, they do do them but dont carry stock and you cant buy them anywhere as they are not an official line ;)
Ok ... I'd be surprised if you get a different answer but hey, surprise me! ;)
JimmyC
Fri Jun 23, 2006 2:18 pm
They can still do them but need a minimum of 10 and are not keen to deal with the general public.
If there was enough interest I may be able to sort it, but they would want people to buy seats aswell
Jimmy
Rizzo
Fri Jun 23, 2006 5:14 pm
The usual story then? hehe
Well if anyone has a used set I could buy that would be fantastic!
Other than that I guess I will have to make some bars as well.
Cheers!
Cotty
Hartge Crew
Fri Jun 23, 2006 10:47 pm
Interesting. I have been thinking about putting Sparco buckets in mine ( either Rev's or Evo XL's for fat passengers)
JimmyC
Sat Jun 24, 2006 4:41 pm
We all use Cobras as i get them dirt cheap for the racers, cheaper new than 2nd hand ebay ones
We use the Evo with lateral supports, great seats
ChrisR
Wed Jul 12, 2006 10:23 pm
I've a couple of cobra base mounted seats which I'd recomend, the drivers with cobra's adjustable mount which is sooo easy to fit and the passengers using 2x 5mm thick ali plate rails, just cut the plate to 60mm width and slightly longer than the seat is wide then drill 4 holes in each one, gives a low position and saves £60 on a mount
matthew_h
Thu Jul 27, 2006 11:03 pm
I'm currently fitting some new seats in my M3 and bizarrely have ended up with a very similar method to that shown above. Ollie's is a lot neater than mine though with all that fancy welding but hopefully mine should work just as well.
I'm mounting some Recaro Speed seats on runners though which is proving slightly problematic but hopefully should be sorted over the weekend.
Interesting to see that we have ended up with very similar solutions but completely independently
