Full Roll Cage
m-dtech
- Unapproved Trader caution
Im looking for a full cage anyone got one spare ?
Cabrio
Hi
Can get you a new Safetydevices cage with X bar and harness bars and door bars from AutomacGB Ltd...at a discount if interested
They are available now and in stock
m-dtech
I can get the omp 6 point cage on next day delivery.
whats the difference with the safety devices one ?
Cabrio
Hi
Would have thought tweeks can supply OMP or Sparco cages next day
Not in a position to knock other cages, its for you to decide upon quality/price/fit/suitability etc
The Safetydevices cage has a good reputation and comes with X diagonal and harness bars to rear and all fittings and bolts etc...door bar available
They are suitable for all racing and the rallying RWD challenge, options for sunroof and non sunroof cars.
If you want to discuss it properly can chat with you on the phone, but as stated no direct experience with OMP to knock it...they are a company who makes lots of good accessories for racing, Safetydevices have been building cages for a long time.
If you need a rollcage you have options but they will all do a job and are available
m-dtech
at end of day OMP seems to be easiest to get a hold of and at a reasonable price.
what kind of price is safety devices stuff ?
Cabrio
Safetydevices price depends upon applicable discounts etc available as stated and are available now.
What price is the OMP you have been offered, know safetydevices can be cheaper than Tweeks price but is your decision based only on price as fit and construction need to be a consideration
If you are happy with OMP then by all means go for it
Lloydie38
Just to jump in here
I bought a OMP 6 point cage from Deemon Tweeks as it's only going to be used for track days and the occasional drive so it will do for me. The cost was approx £430 delivered to me in the Isle of Man, it only took 3 days and comes with all the fittings (which some people have said it doesn't..!?! It's going to be fitted this month but I think it's fair to say it's an 'Entry level' cage.
It all depends on what the car is being used for, if it is more than occasional use it's worth getting something of a higher specification to the OMP but I was also on a budget.
Good luck with the choice
Cabrio
Lloydie
Surprised to hear the OMP might not be up to extreme use, to be fair I have been told stories about other cages and it can depend sometimes on the use the cage has had and the way it was fitted etc.
The Safetydevices cage is strong and has a good reputation and if any fitting parts are missing all companies should supply later, but all branded cages should be fit for purpose...thats what you have to consider.
As stated, and agree depends on use and budget etc
Taffy
Custom Cages are the best available, has a Safety devices one and it was heavy and not that extensive, CC was the best we used and the one that is most commonly used in Kumho and other major racing championships
please contact admin with regard to sig
Cabrio
As stated its a case of fit for purpose and cages can be built to suit and the company that supply the SD cages do offer a service to add triangulation etc to the standard cage..which as said before has full X diagonal so not like the old cages
If you pay the price you can or should get what you want
You pay the price etc etc
Taffy
But the CC has triangulation as standard as should all decent cages, SD are decent but in terms of weight and quality the CC is a better product and that is why it's mostly the cage of choice for E30 racers in Kumho and elsewhere. If you want a bolt in one that will just add some strength then SD / OMP is the way to go but if you want ultimate safety and rigidity then CC is the way to go
Lloydie38
The OMP is fine and will be up to the job without a doubt, FIA approved. However if I was racing in a championship I wiould be looking at a full weld in cage as Taffy has mentioned in other posts as that is completly different on many levels to occasional track day usecabrio wrote:Lloydie
Cabrio
Hi
dont think m-dtech said what the intended use was/is...or whether cost/safety/weight were prime concerns
Then advice would be accurate for use and original post
Lloydie38
I think we've all given him our views from all the angles for him to make a decision
How helpful are we ? VERY
Cabrio
Maybe too helpful.
..as he has not replied for some time
m-dtech
Its for rally use.
OMP cage to my door is £380. 6 point cage with door bars.
sounds like bull shit sales talkSafetydevices price depends upon applicable discounts etc available as stated and are available now.
m3ben05
m-dtech
i found a better deal ;)
paulg390
Don't blame you for not wanting mine at £100 postage !!!!!!
Fleabay here it comes....
Cabrio
Hi...not sales talk...and defo not bullshit that out of order and I hope it was in jest
As discounts for BMW RWD challenge..although have to use Safetydevices cages...also for BMW car club members and for Kuhmo etc
But you are sorted now so good luck but dont think you will be able to enter the car in the RWD challenge for 325s!! with an OMP cage
Let me know how you get on fitting it etc
agent006
So backhanders work even after the company has re-opened under new management then?cabrio wrote:dont think you will be able to enter the car in the RWD challenge for 325s!! with an OMP cag
Cabrio
Maybe you need to explain that last comment as not clear what you are implying but backhanders dont work with me..and not sure what new management you are talking about hence 'what are you saying'..try to be less subtle, and more helpful
agent006
I'm saying that there's probably a reason why there's a compulsory rollcage manufacturer for the RWD challenge series. Why not just state that it has to be of a certain construction standard (multipoint, triangulated, FIA approved etc) rather than from a specific manufacturer. Just seems a bit odd to me that's all. I can undersatnd it with using control tyres as they're a direct influence on competitiveness, but forcing everyone to one rollcage manufacturer just seems a bit "you scratch my back, i'll scratch yours" , that's all.
I should add that i'm the most cynical person this side of Newsnight, so as usual it's probably nothing like what i assume.
Cabrio
Hi
You have explained some of your comment, but not the new management etc...
You should be cynical with the people organising the challenge if you think there is something wrong not the cage manufacturer...so think you should offer an apology as your comment was a bit strong.
As I understand it if a car was built before the challenge started then you can run other cages...I understand your observation and agree that if you dont get a performance advantage then why restrict it.
I or the suppliers of the cage have anything to do with the regulations so I think you were out of order to direct these things towards those not responsible...why dont you go on the forum for the challenge and state this...you may find people share your views but suspect it will not change the regulations as they also have restrictions on tyres, suspension, engines are to be standard as are exhausts etc
I looked at the challenge myself but decided against it due to restrictions but there are plenty who are competing and enjoying it
I await your apology or retraction
agent006
New mangement - SD went into administration and were bought out last year, production moved to poland to save money.cabrio wrote:You have explained some of your comment, but not the new management etc..
You obviously have a vested interest in this somehow. Who are you? SD mangement? supplier? fitter?
Cabrio
Hi
I think your knowledge is flawed as Safetydevices is still operated by the same owners as always been, so you need to be careful what you are saying...it is true they have moved production overseas.
They now have specialists selling cages for them...I know the BMW supplier including the E30 cages hence one of the reasons why the race and rally cars we are building have these cages, any why I know they are good.
Still waiting for your apology...guess you dont do those..lifes too short to get worked up but try and get your facts straight in future
agent006
Why are YOU demanding an apology? I haven't accused YOU of anything. You're not SD management and you didn't draw up the RWD challenge regs, so you are merely an interested 3rd party like me.cabrio wrote:Still waiting for your apology...guess you dont do those..lifes too short to get worked up but try and get your facts straight in future
m-dtech
woah mods lock i have my answer thanks
