In the middle of swapping the engine in my e30 and i'm looking to uprate the subframe at the same time, the cars will be a daily but i still want to hammer the back roads. I'm looking to keep a 4 stud pattern but upgrade my subframe and brakes, basically.
Has anyone went this route before?
What setups did you run?
remove if in the wrong catergory
Suspension setups for back roads and occasional track use
flybynite
I think people tend to say the Bilstein/Eibach B12 setup is the best all-rounder. I had it on mine but replaced it with the Koni adjustable setup when the time came. Both are good and swings and roundabouts between them. I have the Bilsteins going back on because I feel like a change and they are more original.
Depending on how much you want to spend KW do a good coilover kit which has good feedback. I like KW and it will be going on my other one.
Do not go cheap on coilover
steve_k
my set up is.
koni yellow shocks F/R.
custom springs based on the e46 m3 (can't remember the weights).
eibach adjustable ARB's.
eibach/spc adjustable front top mounts.
mk3 mondeo rose jointed drop links.
m3 adjustable/reinforced rear beam.
-3dg camber all round.
it can get a bit twitchy a speed in a straight line but handles the twisties perfectly (for me anyway).
rix313
By subframe I assume you mean you're going to fit the strengthening plates?
