E36 anti roll bars on E30
redcar
Post Sat Nov 05, 2016 11:47 pm
Hello, does anyone know if the e36 anti roll bars will fit onto an e30?
Reason I ask is that the standard e36 ones are fairly cheap and come in relatively large diameters (even compared to aftermarket e30 anti roll bars).
Will be helpful to know if this has been tried before.
Thanks in advance.
andysheep
Post Sun Nov 06, 2016 12:33 pm
Tried and failed :roll: nice diameter but no way to fit it ,front that is,god loves a tryer,,,,,
andysheep
andysheep
Post Sun Nov 06, 2016 12:34 pm
johnmaccow
Post Wed Jan 18, 2017 9:46 pm
Danthe has one fitted but says took a bit of bracket fabrication.
redcar
Post Wed Jan 18, 2017 9:52 pm
Cool, do you know if there are any photos of it fitted?
Post Wed Jan 18, 2017 10:21 pm
Easiest way to 'up' the diameter of an E30 front ARB is to weld brackets to the struts and use M3 type drop links. Doesn't increase the loadings on the (fragile) ARB mounts on the subframe either.
