Fuel tank weight
rix313
Post Thu Dec 17, 2015 9:24 am
Has any one weighed a standard fuel tank with pump assy, pipes etc?
jmc330i
Post Thu Dec 17, 2015 10:39 am
ETK lists a '91 325i tank as 11.6kg. A quick round up of the listed weights for the pump, senders and filler neck and I guess you could add another 2.5kg-3kg as a rough estimate.
James
'91 325i Sport
'93 318i touring 16v
rix313
Post Thu Dec 17, 2015 4:51 pm
I've never been too sure how accurate the weights are on there. I will be pulling mine out soonish so I guess I can compare then. Cheers :thumb:
Jarno
Post Wed Dec 30, 2015 4:55 pm
rix313 wrote:Has any one weighed a standard fuel tank with pump assy, pipes etc?
No, but I weighed the left half of it with breather pipes that run on top of the tank. 4,258 kg. I only have the passenger side of the tank in the car, to improve weight distribution and lightness :D.
